Part Number: TPS53681
Hi team,
When I programmed TPS53681, the programming was unsuccessful due to below error. I’ve attached the file. The output file was created under offline mode.
On the problem, we reproduced the .csv file by using old version TI FUSION (7.4.1) and it can work. The first attachment is produced by 7.7.1 version. I compared these 2 files and found the file using 7.7.1 have much more lines. The .csv fine using 7.4.1 only has 89 lines.
I think this problem might be come from the bug of TI fusion? Can you help to confirm the reason.
TPS53681 0.0 Address 89 PMBus Programmer Script_7.4.1.csvTPS53681 0.0 Address 89 PMBus Programmer Script.csv
Thank you for your support.
Comi
