Other Parts Discussed in Thread: LM51581
I have three electronic cards with the IC damaged at the first start, between VCC and GND i found about 1ohm.
The component is supplied by a voltage regulator with 11V output and the voltage (for the LM5170: the maximum supply voltage is 14V, raccomanded max 12V) is stable in all conditions.
During the power on the voltage rise to 11V in 47ms and there aren't overvoltages.
Do you have any suggestions?
