Hi Team,
the datasheet only mentions 120pF as option for the Cff. My customer doesn't has this option avaiable. Can they also use 100pF or 220pF instead?
Simon
Hello Simon,
Thank you for reaching out,
The feedforward (Cff) will affect the step load performance. A higher Cff will result to lower overshoot/undershoot, but extended the recovery time. TI has only evaluated the Cff value from 0 to 120pF. If you would like to use the higher value for Cff, then you need to take care about the stability concerns. Please do stability analysis in case if you are using a higher Cff value.
You can perform the stability analysis by using Bode 100. Please find the attached document guiding to the bode plot measurements.
Stability related resources:
Simplifying Stability Checks (Rev. B) (ti.com)
Understanding and Simulation of Loop Stability Test for DC/DC Converters
Thank you & regards,
Moheddin.
Hello Simon,
If you don't have any further questions can you please close the thread by clicking on Resolved.
Moheddin.
