Hi team ,
I've some questions.
1-) In the main design of "LM5046EVAL" there is a digital isolator and low side driver for SR Rect. so i have used a UCC21220ADR for SR rectification like the figure below. Do you think its ok?
2-) İn the main design of "LM5046EVAL" there is a second auxiliary for supplying the IC's at the Secondary Side . Instead of the aux coil, I used an LDO wich fed directly from the main output.
( "TPS70933DRVR" ) . Do you think its ok for supplying the IC's at the secondary side.
3-) also my feedback komponents are like the figure below what do you think? There are many different things like compared with the EVM.
Thanks.
