about UC3526
Other Parts Discussed in Thread: UC3526
im working with UC3526, in push pull power supply, i need application note for this,
as im checking in normal board, tested only IC, kept rt, ct, and softstart capacitor,
their is no waveform at Ct, could any one help me out,, i have changed the ICs even, but no result... connections everything i have checked,,
  • Rashmi,
    Make certain that you have at least a 1 uF cap from Vin to GND and that Vin and Vc arre connected. You need a resistor to Rd as well as the ones you have added. connect a 0.1 ceramic from Vref to GND.
    Apply a 15 volt supply between Vin and GND. Verify that Vref comes up and when that happens the clock should start.
    John
