TPS2663: Reverse polarity protection while using surge protection diode
Part Number: TPS2663
We are using the TPS26631 and we used the same simplified schematic in pag.1 of the datasheet. We use both the FETs for RPP and RCB and D1 for surge protection. When the serge protection diode is present, in case of reverse polarity the surge protection diode would be protecting the downstream device rather than the FETs, but it would draw high current from the upstream power supply. Is this the intended behavior in this configuration? Or am I missing something?
Carlo
