Other Parts Discussed in Thread: BQ40Z50, BQSTUDIO
HI,
I have an battery with led display of RSOC.However, after removing the charger, the led light takes 3 seconds to go off. How to set the led to go off in about 1 second?
HI,
The amount of time the LED is held on is determined by the LED Hold Time seen below from the bq40z50 Technical Reference Manual.
https://www.ti.com/lit/pdf/sluua43
If you are using bqStudio, this value can be altered by going to Data Memory -> LED Support -> LED Config.
Anthony Baldino
