LM5116: Buck converter will not startup in no load
Part Number: LM5116
I have buck converter work fine except when I turn on in no load condition, it does not regulate to the correct output voltage, if I ally any load it will regulate. if I start in as low as 5mamps it will regulate, if the load is removed after it starts to regulate it works fine. any ideas what could be the issue
