I have a couple questions I couldn't find answers to in the datasheet.
Is the VCC regulator always on when VIN is applied, or is VCC disabled when EN is below 0.5 V?
If VCC is disabled during shutdown, does this also apply to the VCCX switch?
Basically I was hoping to use VCC or VDDA to translate the 3.3 V enable signal from my MCU to a 5 V signal for a different part of the circuit. A separate switching regulator supplies VCCX with 5 V.
Thanks!
