Other Parts Discussed in Thread: UCC2808-1
Can you comment on the following questions:
1) OUTA/OUTB Source Current: The UCC2808 lists -0.5A as a minimum whereas the UCC2808A lists -0.5A as a maximum. Is this an error? Should they both be listed as minimum?
2) HBM ESD Rating is 1000V less for the UCC2808A. Is this correct? Why?
3) There is a slight variation in the COMP pin source current. Is this a typo or is there really 50uA less in the minimum current sourcing?
Thank you in advance, Kurt
