Hi team,
Datasheet figure "Figure 9-18. PWM to Bypass Transition in CCM Operation" has "pulse skipping" duration before and after bypass mode. Considering LM5152-Q1, high side switch must be turned on in bypass mode. I understood as lower. Could you confirm if my understanding correct?
(1) Before bypass operation, VIN is really close to VOUT and tON < tON_MIN, then, pulse skipping mode starts. Pulse skipping mode is finished and transition to Bypass operation after 40us in OVP status. At least in this duration, pulse skipping mode should be exist before bypass operation.
(2) In pulse skip mode, is high side FET turned off as well as low side FET?
(3) After Bypass operation, VIN may still be closed to VOUT and tON < tON_MIN, then pulse skipping mode happens. In the case of tON > tON_MIN and no light load condition, pulse skipping mode may be not exist after bypass operation.
Ochi
