As you already know, we'll have "D" revision. But on some project variants we are changing the GPIO from input to output , will Revision “D” affect this operation ?
# Device address, register address, register value, CRC byte
0x60,0x02,0xDD,0x91, # Unlock the control
0x60,0x04,0x12,0x8C # Disable config CRC check to avoid interrupt
0x60,0x05,0xAA,0xB8 # Unlock the config.
0x60,0x06,0X39,0x77 # Config GPIO pin as output
0x60,0x29,0xEE,0x31 # Update the CRC config
0x60,0x4A,0x2D,0xBC # burn to EEPROM
Will we still be able to burn this into the EEPROM with revision “D”?
Note: This is done one time only
I asked this question to Piotr as well, but you know the device better.
Have a nice day!
