We are using TPS61288LRQQR for stepping up 6.2V to 18V. I am attaching the design below. Is there any suggestions in this? Also, are the compensation network values correct?
Hello Ardra M,
Something went wrong with the attachment, I cannot find it, please share again.
In general I recommend comparing the schematic with the one given in the application section in the datasheet. For the compensation, you can check with the design calculator here: SLVRBH4 Calculation tool | TI.com or you can do a Webench design.
Brigitte
