The data sheet does not show what the orienttion of this device is relative to the "sproket holes" in the reel tape.
Is below correct or is it the other way around?
Thank you!
Thank you!
Hello Kurt,
Thanks for the inquiry. This looks correct. According to the tape & reel information at the link below, pin 1 is in quadrant 2, upper right hand pocket quadrant. I also confirmed this in ATSS (Assembly Test Spec System). I copied pasted it below.
https://www.ti.com/packaging/docs/carriermaterial/carrierlookup?OPN=CSD19536KTT
**** EIA/QSS STANDARD PIN 1 ORIENTATION IN TAPE ****
O O O O O O O O O O O >>>SPROCKET HOLES (CIRCULAR)
| | O| | >>>PIN 1 CORNER OF UNIT
*#TR PIN 1 QUADRANT: 2
John Wallace
TI FET Applications
