Hi
I have questions about TPS23754EVM-420 Schematic (slvu301)
Should I use diode (D13,D14) ?
Could you pls tell me the reason.
Hi
D14. always. It protects against input overvoltage due to hotplug to 50V (classic L-C ring with step voltage) or current-limited pass MOSFET turnoff (energy storred in input wiring and devices).
Use of D13 and a number of other devices is dictated by your application. Predominantly these are there for PSE priority and PSE hot backup of adapter ORing. See SLVA306A and the datasheet for guidance.
Refer to DRTN in the datasheet (pg 26 of http://focus.ti.com/general/docs/lit/getliterature.tsp?genericPartNumber=tps23754&fileType=pdf) and the adapter ORing application note (pg 9 of http://focus.ti.com/general/docs/lit/getliterature.tsp?literatureNumber=slva306a&fileType=pdf).
