Hello team,
My customer is wondering if the ILIM of the TPS61376 can be changed dynamically (i.e. after the device has started up already with a given current limit).
For example, if part way through operation the RILIM1 resistor is switched to a different RILIM2 would the ILIM change or is this only performed at device start-up?
Also, is this reading of the RILIM done via a voltage measurement? Could a DAC be used in this case to control ILIM?
Austin Allen
