Hi team,
Is there a recommended rage for pull up resistor on PG-pin?
Also, the datasheet shows 100kohm as an example, may I know the reason why it is 100k?
Kurumi
Hi team,
Kurumi
Hi Kurumi-san,
For the minimum pull-up resistor across PG pin, limit the max sink current to 2mA. Typically, 1Mohm would be maximum value to avoid external noise influencing the PG level.
I hope I was able to answer your queries.
Excel
Hi Kurumi-san,
Do you have further queries? If not, can you kindly close the thread.
Thank you.
Excel
Hi Excel,
Thank you so much for your reply. There is no additional question, so I'd like to close this thread.
