When I was using the TPS65150 chip, I tested that the 5, 6 pin (SW) of the chip did not output waveform, I do not know what problems caused it. The schematic design is as follows:
Hi Hao,
Have you captured any waveform during your test? You can send me the AVDD, VGH and VGL when you powering on the IC.
BR
Patrick
Hi Hao,
I suggest to capture these waveform to understand the start-up behavior.
BR
Patrick
Hi Hao,
The minimum VGL of this part is ~ -(V_AVDD-1.13V), but now you are programming a much lower VGL.
BR
Patrick
Hi Hao,
Please refer to below AN. The VGL is supplied from AVDD, so its output range is limited by AVDD as well. If you program an over range VGL, the IC couldn't regulate the programmed value and finally trigger UVP fault to shut down all the outputs.
BR
Patrick
Hi Hao,
Please refer to datasheet "7.2 Functional Block Diagram", the VGL is supplied from Vsup (AVDD).
BR
Patrick
