Hello team,
My customer is doing the test as below:
They use the external supply to VCC pin, EXTVCC pull low. But at real test, they disconnect VCC pin to 5V supply.
Here is their test result:
VCC would have a small raise follow Vin, then with the EN pin pull up, the VCC pin will keep at 1.2V. You can see the waveform as below.
Question:
1. Does VCC voltage come from Vin even choose external supply? Please help explain the voltage change in the waveform.
2. Will this 1.2V influence the IC work normally? Please help evaluate the risk here.
Lanxi
