Other Parts Discussed in Thread: USB2ANY, TPS55289
TPS55289EVM and USB2ANY are not connected. Is there any reason?
The following is downloaded.
・TPS55289_1.1.0_installer_win
・slvc695
Regarding USB2ANY Explorer, it does not connect even if you change the firmware location.
The jumper PIN is also set based on the hardware setup instructions.
Is it a hardware problem?
