Other Parts Discussed in Thread: BQ79616, , BQ79656-Q1
Hello experts,
I am currently in the process of designing a battery management system (BMS) using the BQ79616 IC. I understand that this particular IC doesn’t have built-in current sensing capabilities. My design comprises a modular system with 7 battery modules in series. My goal is to monitor the current draw of each individual module. If any module draws more current than expected, I want the capability to shut it off or potentially bypass it.
To avoid connecting each shunt resistor directly to the main controller card, I am contemplating adding a microcontroller to each slave BQ79616 board. Before I proceed with this approach, I have a couple of questions:
- Do you think it's advisable to use a separate microcontroller with each BQ79616 for current sensing? If so, could you recommend a compatible TI microcontroller that would work harmoniously with the BQ79616?
- Alternatively, is there another IC within the TI portfolio that combines the capabilities of the BQ79616 with current sensing?
I appreciate your insights and suggestions. Looking forward to enhancing the robustness of my BMS design with your expertise.
Batuhan
