TLV62130: Discharge from output to input
Part Number: TLV62130
Hi Team,
currently we are using TLV62130 part. As per our application there will be a voltage generated on the Vout pin when there is no vin. We just want to confirm whether the diode present internally is reverse path blocking supported or not.
As per datasheet i am seeing a 2 NMOS which will allow the reverse current flow. Pls let us know whether this is correct or not.
