Hi i would like to have my Bq24616 schematic and PCB reviewed. The board is without DPM enabled. I will share the files on private chat.
Thanks and regards
Noel Binny Abraham
Thanks and regards
Noel Binny Abraham
Hi Noel,
Thank you for reaching out!
Please see the following thread for a schematic checklist: https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/791790/faq-bq24610-bq24650-bq24610-bq24650-schematic-review-design-tips
Also, kindly accept my friend request so that you may share files on private messaging.
Aya Khedr
Just did. I am sharing you the files now.
Will check the given checklist. Thanks
Hi Noel,
I received your files and will review and provide feedback by Friday (or Monday the latest).
Aya Khedr
Hi Noel,
Please see my comments below:
1- Input protection: We recommend using a diode to block reverse current/voltage at the input if back-to-back MOSFETs are not included.
2-If DPM feature is not required, ACN and ACP can be shorted together or tied to VCC and ACSET can be tied directly to VREF
3- Please see table below for typical inductance and output capacitance as a function of charge current. For 10A charge current, a 3.3uH inductor should be used with 40uF output capacitance.
4- See attached calculations for the BQ24616 according to your design parameters and make sure they align with your requirements (sent in private)
For example: See TS resistor network and input NTC thermistor R_COLD and R_HOT and make sure values align with your requirements.
5- What is the purpose of R10 and R3? What is the intended total resistance here?
Aya Khedr
