I've attached a ckt built around TPS62110. This is in use in our design, yet after some recent testing C149 on the output of this converter was found to be damaged by EOS. We are having trouble figuring out what could have caused the EOS condition in this ckt. Do you have any experience with this type of problem? Some people are suggesting the converter is going into oscillation somehow or that there is not enough capacitance to handle the 3 inductors once we apply the voltage, temp and tolerance deratings. Ripple was measured on another board to be about 0.425Apk-pk. We don't see this problem frequently at all, but it is a solid electrical failure we would like to sort out before mass production. Thanks! JM
