Hi team,
It says "Buck-only mode" in Feature.
Can bq25756 be used only as a buck charger?
If yes, can the FET on the boost side be removed?
Hi team,
Hello Hirotsugu,
This is a typo in the datasheet. The BQ25756 does not have a buck only mode. Thanks for being patient with this.
Ethan Galloway
Hi Ethan,
If this IC is used only for charging under Buck mode conditions, is it possible to remove the boost-side FET?
Hello Hirotsugu,
The BQ25756 needs both buck-side and boost-side FETs for the compensation detection. The boost-side FETs can't be removed.
Ethan Galloway
