Could you share the different between LP8864 and LP8866?
I check LP8864 and LP8866 pin compatible completely, so if have some different in actual design?
Look forward to your reply
Hi, Duo
Difference between LP8864 and LP8866 is channel number, and the setup resistor. You can compare it with the datasheet.
