BQ40Z50: Disable / Deactivate Fuse Pin 25
Part Number: BQ40Z50
In regards to disabling the fuse pin 25 in the BQ40Z50 IC, is the correct approach to take the pin directly to ground? Should a zero ohm resistor be used or is this practice unnecessary?
Any guidance you can provide would be appreciated.
Joe DeWitt
