Other Parts Discussed in Thread: TPS54561,
Hello TI,
why there is 0.8 in eq(9) of tps54331 datasheet? it's different from tps54561.
Hello Kingson,
I will check and reply you soon.
Hello Kingson,
I think the 0.8 factor is considering 80% efficiency or 80% effective inductance. But agree with you, I more often to see this equation without this factor. I would say it's not good to add it without any explanation.
Thanks for point out! I will add it into our backlog.
Hello Miranda
Because the actual duty cycle is related with efficiency, duty cycle =Vout/(Vin*n), normally efficiency n is thought as 80% ?
