BQ24080 CE# pin question
Other Parts Discussed in Thread: BQ24080
On datasheet (P.13) it states that a low-level signal on Charge-Enabled Input pin enables the charging, but on the typical application circuit from the same datasheet (P.17), the CE# pin is held high constantly. Is this an error on the datasheet, or am I misunderstanding the datasheet? Could someone possible clarify please?
BQ24080 datasheet: http://www.ti.com/lit/gpn/bq24080
