We want to control TPS65313 to perforn the reset.
I use the CLR_WAKE_LATCH command, but 3.3V output cannot drop to 0v.
Does TI have recommend reset sequence for TPS65313
The blue line is TPS65313 3.3V output.
The yellow line is C2000 MCU XRS PIN.
Hi WZ,
Couple things you can try:
1. Before using the CLR_WAKE_LATCH command pull the WAKE pin low
2. Disable auto start by setting AUTO_START_DIS to '1'
regards,
Niko
OK. One question:
Before using the CLR_WAKE_LATCH command pull the WAKE pin low, will the TPS65313 reset?
Due to I can control the WAKE pin to low, but then when TPS65313 enter into off state by CLR_WAKE_LATCH.
C2000 MCU is no power any more. The WAKE PIN will relay on other hardware circuit such as CAN Wakeup to set WAKE pin to high again, then C2000 MCU will be powered.
This is not reset, this is sleep. It will relay on other hardware circuit such as CAN Wakeup to wake.
Hi WZ,
This will power down the device to the OFF state. If this is not viable option then you can try the option 2. So first set the AUTO_START_DIS to '1' and then perform CLR_WAKE_LATCH command.
regards,
Niko
Hi WZ,
this is described in the section you showed the screenshot of. (8.13.1 OFF state).
regards,
Niko
i checked this chapter.
Your suggestion option2, accdoring to the datasheet.
I cannot reset.
Need a new rising edge is detected at the WAKE pin. I cannot offer this condtion, just want TPS65313 reset like C2000 DSP software reset or watchdog reset, it shall reboot itself.
Hi WZ,
I am looking into this and will get back to you tomorrow.
regards,
Niko
Hi WZ,
understood. I am still looking into this and trying to get results in the beginning of next week.
regards,
Niko
Hi WZ,
sorry for taking time on this. I am still looking into this. Expect a reply tomorrow or early next week.
regards,
Niko
Hi WZ,
sorry for the late reply. Now I have access to an EVM so I can test this. I am trying to get an answer today.
regards,
Niko
Hi WZ,
the best way would be to go to OFF state by CLR_WAKE_LATCH and by toggling the wake pin enable the regulators again. There is no other dedicated sequence for this. Other possible way could maybe be by using the MCU_RST_RQ command. This command requests the PMIC to toggle the NRES pin low and back to high.
regards,
Niko
I cannot offer this condition.
I will try this CMD, have you already tried with EVM.
Hi WZ,
this command pulls the nRES pin low and back high again to reset the MCU which I have tested on the EVM.
regards,
Niko
