Hi TI Team,
Requesting to provide LM5181-Q1 IC, TC pin input leakage current, which will help in our design.
Kind regards,
Vamsi Bankuru
Hi TI Team,
Kind regards,
Vamsi Bankuru
The voltage of TC pin is shown below. You can get the current value based on this parameter and Rtc. Hope this can help. Thanks.
Aurora
Hi Aurora,
Okay, let's consider Rtc as 127Kohms, can you please specific the input leakage current flow through the TC pin. Please make a note that other end of Rtc is not connected to ground.
Kind regards,
Vamsi Bankuru
Sorry, there is something wrong with what I said before. The voltage of Rset pin is 1.21V. So the current of TC pin is very small, you can use the voltage difference and resistance to estimate. Thanks.
Aurora
Hi Aurora,
Is there any other way to get the current, as the potential difference between Rset and TC pin will give the current flowing through the Rtc resistor. Can you please confirm, is that current is the actual input leakage current of TC pin.
Kind regards,
Vamsi Bankuru
Hi Aurora,
Can you please let me know the minimum TC pin voltage.
Kind regards,
Vamsi Bankuru
Hi Vamsi,
We don't have this spec. Inside the TC pin is a voltage source with limited current. The actual current value is very small, uA level. At normal temperature, its voltage is equal to the Vref voltage, and there is no current on Rtc. Thanks.
Aurora
Hi Aurora,
Is it possible to get the information regarding TC pin.
Kind regards,
Vamsi Bankuru
Hi Vamsi,
Maybe you need to measure the voltage of TC pin under different temperature. We don't have the data of minimum TC pin voltage. Thanks.
Aurora
All the data we have has been marked on the datasheet. Others may require you to actually test them based on your specific application. You can apply for our LM5180EVM for evaluation. Thanks.
Aurora
Maybe you need to contact the European FAE to help you apply. I'm sorry that I am in China and cannot to help you apply for a EVM. Or you can buy it on our official website. Thanks.
Aurora
Hi Aurora,
Can you please provide the efficiency characteristics.
Kind regards,
Vamsi Bankuru
You can use webench to get efficiency under your application. You can find the link on our official website. Thanks.
Aurora
