BQ40Z50: R3: Unable to read through MAC commands
Part Number: BQ40Z50
I am trying to read some of the blocks through MAC commands, but am not able to get it working.
For example when I try runnng commands through the GUI, some work and some don't.
Like in the screen shot above, the chem_id is the only command that works and the rest give a result as N/A. Not sure if the commands were successful or not.
Also, when I try to read the chem_id through block read, I get the same wrong data - "54 00 87 02 00 00" irrespective of the command
Also, how do a block read for a register such as the below?
Please help achieve the block read for MACs.
Below are the system / software details:
*** Date: Thursday 26 October 2023 at 11:54:31 pm India Standard Time
*** Platform Details:
*** System properties:
applicationXMI=org.eclipse.ui.workbench/LegacyIDE.e4xmi
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=com.ti.evswsdk.evswsdk
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
-launcher
C:\ti\BatteryManagementStudio\bqsbb.exe
-name
Bqsbb
--launcher.library
C:\ti\BatteryManagementStudio\\plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.300.v20150602-1417\eclipse_1611.dll
-startup
C:\ti\BatteryManagementStudio\\plugins/org.eclipse.equinox.launcher_1.3.100.v20150511-1540.jar
--launcher.overrideVmargs
-clearPersistedState
-persistState
false
-vm
C:\ti\BatteryManagementStudio\jre\bin\client\jvm.dll
eclipse.home.location=file:/C:/ti/BatteryManagementStudio/
eclipse.launcher=C:\ti\BatteryManagementStudio\bqsbb.exe
eclipse.launcher.name=Bqsbb
eclipse.p2.data.area=@config.dir/../p2
eclipse.p2.profile=profile
eclipse.product=com.ti.evswsdk.product
eclipse.startTime=1698305812181
eclipse.stateSaveDelayInterval=30000
eclipse.vm=C:\ti\BatteryManagementStudio\jre\bin\client\jvm.dll
eclipse.vmargs=-Dosgi.requiredJavaVersion=1.8
-Xms40m
-Xmx512m
-Djava.class.path=C:\ti\BatteryManagementStudio\\plugins/org.eclipse.equinox.launcher_1.3.100.v20150511-1540.jar
equinox.use.ds=true
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
gosh.args=--nointeractive
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.version=52.0
java.endorsed.dirs=C:\ti\BatteryManagementStudio\jre\lib\endorsed
java.ext.dirs=C:\ti\BatteryManagementStudio\jre\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
java.home=C:\ti\BatteryManagementStudio\jre
java.io.tmpdir=C:\Users\jvsingh\AppData\Local\Temp\
java.library.path=C:\ti\BatteryManagementStudio;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system32;C:\WINDOWS;C:/ti/BatteryManagementStudio/jre/bin/client;C:/ti/BatteryManagementStudio/jre/bin;C:/ti/BatteryManagementStudio/jre/lib/i386;C:\Program Files\Common Files\Oracle\Java\javapath;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\MATLAB\R2021b\runtime\win64;C:\Program Files\MATLAB\R2021b\bin;C:\Program Files\MATLAB\R2021a\runtime\win64;C:\Program Files\MATLAB\R2021a\bin;C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin\;C:\Program Files\IVI Foundation\VISA\Win64\Bin\;C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin;C:\Program Files (x86)\Texas Instruments\Fusion Digital Power Designer\bin;C:\Users\jvsingh\AppData\Local\Programs\Python\Python311\Scripts\;C:\Users\jvsingh\AppData\Local\Programs\Python\Python311\;C:\Users\jvsingh\AppData\Local\Programs\Python\Python310\Scripts\;C:\Users\jvsingh\AppData\Local\Programs\Python\Python310\;C:\Users\jvsingh\AppData\Local\Microsoft\WindowsApps;C:\Users\jvsingh\Cypress\EZ-PD Protocol Analyzer Utility\jre\bin\javaw.exe;C:\Program Files\JetBrains\PyCharm Community Edition 2022.1.1\bin;;C:\Program Files\Java\jdk-18.0.1.1\bin\;C:\Users\jvsingh\AppData\Local\Programs\Microsoft VS Code\bin;C:\ProgramData\anaconda3\Scripts\;;C:\ti\BatteryManagementStudio;;.
java.net.preferIPv4Stack=true
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.8.0_74-b02
java.specification.name=Java Platform API Specification
java.specification.vendor=Oracle Corporation
java.specification.version=1.8
java.vendor=Oracle Corporation
java.vendor.url=http://java.oracle.com/
java.vendor.url.bug=http://bugreport.sun.com/bugreport/
java.version=1.8.0_74
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Oracle Corporation
java.vm.specification.version=1.8
java.vm.vendor=Oracle Corporation
java.vm.version=25.74-b02
line.separator=
org.eclipse.equinox.launcher.splash.location=c:\ti\BatteryManagementStudio\configuration\org.eclipse.equinox.launcher\com.ti.evswsdk_1.3.101.202005080856\splash.bmp
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.eclipse.equinox.simpleconfigurator/bundles.info
org.eclipse.update.reconcile=false
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSGi/Minimum-1.1,OSGi/Minimum-1.2,JavaSE/compact1-1.8,JavaSE/compact2-1.8,JavaSE/compact3-1.8,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,JavaSE-1.6,JavaSE-1.7,JavaSE-1.8
org.osgi.framework.language=en
org.osgi.framework.os.name=Windows10
org.osgi.framework.os.version=10.0.0
org.osgi.framework.processor=x86
org.osgi.framework.system.capabilities=osgi.ee; osgi.ee="OSGi/Minimum"; version:List<Version>="1.0, 1.1, 1.2",osgi.ee; osgi.ee="JRE"; version:List<Version>="1.0, 1.1",osgi.ee; osgi.ee="JavaSE"; version:List<Version>="1.0, 1.1, 1.2, 1.3, 1.4, 1.5, 1.6, 1.7, 1.8",osgi.ee; osgi.ee="JavaSE/compact1"; version:List<Version>="1.8",osgi.ee; osgi.ee="JavaSE/compact2"; version:List<Version>="1.8",osgi.ee; osgi.ee="JavaSE/compact3"; version:List<Version>="1.8"
org.osgi.framework.system.packages=javax.accessibility,javax.activation,javax.activity,javax.annotation,javax.annotation.processing,javax.crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imageio,javax.imageio.event,javax.imageio.metadata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap,javax.lang.model,javax.lang.model.element,javax.lang.model.type,javax.lang.model.util,javax.management,javax.management.loading,javax.management.modelmbean,javax.management.monitor,javax.management.openmbean,javax.management.relation,javax.management.remote,javax.management.remote.rmi,javax.management.timer,javax.naming,javax.naming.directory,javax.naming.event,javax.naming.ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.print,javax.print.attribute,javax.print.attribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.rmi.ssl,javax.script,javax.security.auth,javax.security.auth.callback,javax.security.auth.kerberos,javax.security.auth.login,javax.security.auth.spi,javax.security.auth.x500,javax.security.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.swing.border,javax.swing.colorchooser,javax.swing.event,javax.swing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.nimbus,javax.swing.plaf.synth,javax.swing.table,javax.swing.text,javax.swing.text.html,javax.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.tools,javax.transaction,javax.transaction.xa,javax.xml,javax.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotation.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,javax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.crypto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.datatype,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,javax.xml.stream,javax.xml.stream.events,javax.xml.stream.util,javax.xml.transform,javax.xml.transform.dom,javax.xml.transform.sax,javax.xml.transform.stax,javax.xml.transform.stream,javax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax.xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,javax.xml.ws.spi,javax.xml.ws.spi.http,javax.xml.ws.wsaddressing,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.omg.PortableServer,org.omg.PortableServer.CurrentPackage,org.omg.PortableServer.POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg.PortableServer.portable,org.omg.PortableServer.ServantLocatorPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.ls,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.traversal,org.w3c.dom.views,org.w3c.dom.xpath,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.uuid=009b566e-d273-001e-196d-be4949639d54
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.8.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows 10
os.version=10.0
osgi.arch=x86
osgi.bundles=reference:file:org.eclipse.osgi.compatibility.state_1.0.100.v20150402-1551.jar,reference:file:org.eclipse.equinox.simpleconfigurator_1.1.100.v20150423-1455.jar@1:start
osgi.bundles.defaultStartLevel=4
osgi.compatibility.bootdelegation=true
osgi.configuration.area=file:/C:/ti/BatteryManagementStudio/configuration/
osgi.framework=file:/c:/ti/BatteryManagementStudio/plugins/org.eclipse.osgi_3.10.102.v20160118-1700.jar
osgi.framework.extensions=reference:file:org.eclipse.osgi.compatibility.state_1.0.100.v20150402-1551.jar
osgi.framework.shape=jar
osgi.framework.useSystemProperties=true
osgi.frameworkClassPath=., file:c:/ti/BatteryManagementStudio/plugins/org.eclipse.osgi.compatibility.state_1.0.100.v20150402-1551.jar
osgi.install.area=file:/C:/ti/BatteryManagementStudio/
osgi.instance.area=file:/C:/ti/BatteryManagementStudio/workspace/
osgi.logfile=C:\ti\BatteryManagementStudio\workspace\.metadata\.log
osgi.nl=en_IN
osgi.os=win32
osgi.splashLocation=c:\ti\BatteryManagementStudio\configuration\org.eclipse.equinox.launcher\com.ti.evswsdk_1.3.101.202005080856\splash.bmp
osgi.splashPath=platform:/base/plugins/com.ti.evswsdk
osgi.syspath=c:\ti\BatteryManagementStudio\plugins
osgi.tracefile=C:\ti\BatteryManagementStudio\workspace\.metadata\trace.log
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.awt.enableExtraMouseButtons=true
sun.boot.class.path=C:\ti\BatteryManagementStudio\jre\lib\resources.jar;C:\ti\BatteryManagementStudio\jre\lib\rt.jar;C:\ti\BatteryManagementStudio\jre\lib\sunrsasign.jar;C:\ti\BatteryManagementStudio\jre\lib\jsse.jar;C:\ti\BatteryManagementStudio\jre\lib\jce.jar;C:\ti\BatteryManagementStudio\jre\lib\charsets.jar;C:\ti\BatteryManagementStudio\jre\lib\jfr.jar;C:\ti\BatteryManagementStudio\jre\classes
sun.boot.library.path=C:\ti\BatteryManagementStudio\jre\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386 i86
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=
user.country=IN
user.dir=C:\ti\BatteryManagementStudio
user.home=C:\Users\jvsingh
user.language=en
user.name=jvsingh
user.script=
user.timezone=Asia/Calcutta
user.variant=
*** Features:
org.eclipse.emf.common (2.11.1.v20160208-0816) "EMF Common"
org.eclipse.emf.ecore (2.11.2.v20160208-0816) "EMF Ecore"
*** Plug-in Registry:
ch.qos.logback.classic (1.0.7.v20121108-1250) "Logback Classic Module" [Resolved]
ch.qos.logback.core (1.0.7.v20121108-1250) "Logback Core Module" [Resolved]
com.ibm.icu (54.1.1.v201501272100) "International Components for Unicode for Java (ICU4J)" [Active]
com.ti.bqkeylib (1.0.0) "Bqkeylib" [Resolved]
com.ti.evswsdk (1.3.101.202005080856) "Battery Management Studio" [Active]
com.ti.evswsdk.adcreadout (1.0.0.202005080856) "ADC Readout" [Starting]
com.ti.evswsdk.altchem (1.0.0.202005080856) "Chemistry" [Starting]
com.ti.evswsdk.authentication (1.0.0.202005080856) "Authentication" [Starting]
com.ti.evswsdk.autodetect (1.3.0.202005080856) "Autodetect" [Active]
com.ti.evswsdk.bmdk_main (1.0.0.202005080856) "com.ti.evswsdk.bmdk_main" [Resolved]
com.ti.evswsdk.bqkey (1.0.0.202005080856) "Bqkey" [Starting]
com.ti.evswsdk.bqkeyprog (1.0.0.202005080856) "BqKey Programmer" [Starting]
com.ti.evswsdk.calbq27z746 (1.3.0.202005080856) "Calbq27z746" [Starting]
com.ti.evswsdk.calbq40z451 (1.3.0.202005080856) "Calbq40z451" [Starting]
com.ti.evswsdk.calbq769x2 (1.0.0.202005080856) "Calibratebq769x2" [Starting]
com.ti.evswsdk.calbq78350 (1.0.0.202005080856) "Calbq78350" [Starting]
com.ti.evswsdk.calbq78350_R1 (1.0.0.202005080856) "Calbq78350_R1" [Starting]
com.ti.evswsdk.calibration (1.0.0.202005080856) "Calibration" [Starting]
com.ti.evswsdk.chargecontrol (1.0.0.202005080856) "Charge Parameter Control" [Starting]
com.ti.evswsdk.charger (1.0.0.202005080856) "Charger" [Starting]
com.ti.evswsdk.chargerauthentication (1.3.2.202005080856) "Authentication" [Starting]
com.ti.evswsdk.chargerbackend (1.3.0.202005080856) "Chargerbackend" [Starting]
com.ti.evswsdk.chargercommands (1.3.2.202005080856) "Commands" [Starting]
com.ti.evswsdk.chargerdatagraph (1.3.0.202005080856) "DataGraph" [Starting]
com.ti.evswsdk.chargerdatalog (1.3.0.202005080856) "Datalog" [Starting]
com.ti.evswsdk.chargerfodresistor (1.3.2.202005080856) "FOD Resistor Calibration" [Starting]
com.ti.evswsdk.chargerotp (1.0.0.202005080856) "Chargerotp" [Starting]
com.ti.evswsdk.chargerregisters (1.3.0.202005080856) "Chargerview" [Active]
com.ti.evswsdk.chargertelemetry (1.0.0.202005080856) "Telemetry" [Starting]
com.ti.evswsdk.chem (1.3.0.202005080856) "Chem" [Starting]
com.ti.evswsdk.cmdsequence (1.0.0.202005080856) "Command Sequence" [Starting]
com.ti.evswsdk.commands (1.3.2.202005080856) "Commands" [Active]
com.ti.evswsdk.communication (1.2.0.202005080856) "Communication" [Active]
com.ti.evswsdk.dashboard (1.2.0.202005080856) "Dashboard" [Active]
com.ti.evswsdk.dataflashview (1.3.0.202005080856) "DataFlashView" [Starting]
com.ti.evswsdk.datagraph (1.3.0.202005080856) "DataGraph" [Starting]
com.ti.evswsdk.datalog (1.3.0.202005080856) "Datalog" [Starting]
com.ti.evswsdk.dfimagereader (1.0.0.202005080856) "DF Image Reader" [Starting]
com.ti.evswsdk.dualdashboard (1.2.0.202005080856) "Dashboard" [Starting]
com.ti.evswsdk.eccview (1.0.1.202005080856) "Eccview" [Starting]
com.ti.evswsdk.fieldprogrammer (1.0.0.202005080856) "FieldProgrammer" [Starting]
com.ti.evswsdk.firmware (1.3.0.202005080856) "Firmware" [Starting]
com.ti.evswsdk.fsexport (1.0.0.202005080856) "Flash Stream Export" [Starting]
com.ti.evswsdk.ftdiproview (1.0.0.202005080856) "FTDI Proview" [Starting]
com.ti.evswsdk.gdk (1.0.0.202005080856) "GDK" [Starting]
com.ti.evswsdk.global (1.2.0.202005080856) "Global" [Active]
com.ti.evswsdk.goldenimage (1.0.0.202005080856) "Golden Image" [Starting]
com.ti.evswsdk.goldenizing (1.0.0.202005080856) "Goldenizing" [Starting]
com.ti.evswsdk.gpccycle (1.0.0.202005080856) "GPC Cycle" [Starting]
com.ti.evswsdk.gpcpackager (1.0.1.1) "GPCPackager" [Starting]
com.ti.evswsdk.hdq.proview (1.0.0.202005080856) "HDQ Proview" [Starting]
com.ti.evswsdk.help (1.2.0.202005080856) "Help" [Starting]
com.ti.evswsdk.i2c.proview (1.2.0.202005080856) "I2c Proview" [Starting]
com.ti.evswsdk.i2ctohdq (1.0.0) "I2C To HDQ" [Starting]
com.ti.evswsdk.kf_controls (1.0.0.202005080856) "Kf_controls" [Starting]
com.ti.evswsdk.learningcycle (1.0.0.202005080856) "Learning Cycle" [Starting]
com.ti.evswsdk.logviewer (1.0.0) "Log Viewer" [Starting]
com.ti.evswsdk.logviewer.backend (1.0.0.202005080856) "Log Viewer backend" [Active]
com.ti.evswsdk.monitorauxadc (1.0.0.202005080856) "Protector" [Starting]
com.ti.evswsdk.monitorcellbalancing (1.0.0.202005080856) "Protector" [Starting]
com.ti.evswsdk.monitorcellvoltage (1.0.0.202005080856) "Protector" [Starting]
com.ti.evswsdk.monitorcommctrl (1.0.0.202005080856) "Communication Control" [Starting]
com.ti.evswsdk.monitorcommon (1.0.0.202005080856) "Protector" [Starting]
com.ti.evswsdk.monitorgpio (1.0.0.202005080856) "Monitorgpio" [Starting]
com.ti.evswsdk.monitorprotector (1.0.0.202005080856) "Protector" [Starting]
com.ti.evswsdk.monitorregisters (1.0.0.202005080856) "Registers" [Starting]
com.ti.evswsdk.monitorscripting (1.0.0.202005080856) "Command Sequence" [Starting]
com.ti.evswsdk.monitorstatus (1.0.0.202005080856) "Fault/Status Control" [Starting]
com.ti.evswsdk.parameterqa (1.0.0.202005080856) "Parameter QA" [Starting]
com.ti.evswsdk.programming (1.0.0.202005080856) "Programming" [Starting]
com.ti.evswsdk.programming769x2 (1.0.0.202005080856) "Programming769x2" [Starting]
com.ti.evswsdk.projectmode (1.0.0.202005080856) "ProjectMode" [Starting]
com.ti.evswsdk.proview (1.2.1.202005080856) "Proview" [Active]
com.ti.evswsdk.sbsbackend (1.3.0.202005080856) "Sbsbackend" [Active]
com.ti.evswsdk.sbsview (1.3.0.202005080856) "Sbsview" [Active]
com.ti.evswsdk.seal (1.2.0.202005080856) "Seal Unseal" [Starting]
com.ti.evswsdk.sha1auth (1.0.0.202005080856) "Sha1auth" [Starting]
com.ti.evswsdk.srec2fs (1.3.0.202005080856) "srec2fs" [Starting]
com.ti.evswsdk.targetinfo (1.3.0.202005080856) "Targetinfo" [Active]
com.ti.evswsdk.wpdk.view (1.0.0) "WPDK" [Starting]
com.ti.ftdi (1.0.0.202005080856) "FTDIInterface" [Active]
com.ti.lib (1.0.0.202005080856) "Lib" [Resolved]
com.ti.math (1.0.0) "Math" [Resolved]
com.ti.misc (1.0.0.202005080856) "Misc" [Resolved]
com.ti.oc (1.0.0.202005080856) "OneController" [Active]
com.ti.toolsSDKLibrary (1.3.0.202005080856) "ToolsSDKLibrary" [Active]
javax.annotation (1.2.0.v201401042248) "javax.annotation Bundle" [Resolved]
javax.el (2.2.0.v201303151357) "Javax Expression Language Bundle" [Resolved]
javax.inject (1.0.0.v20091030) "Atinject Dependency Injection Annotations" [Resolved]
javax.servlet (3.1.0.v201410161800) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.2.0.v201112011158) "JSP API Bundle" [Resolved]
javax.xml (1.3.4.v201005080400) "JAXP XML" [Resolved]
org.apache.batik.css (1.7.0.v201011041433) "Apache Batik CSS" [Resolved]
org.apache.batik.util (1.7.0.v201011041433) "Apache Batik Utilities" [Resolved]
org.apache.batik.util.gui (1.7.0.v200903091627) "Apache Batik GUI Utilities" [Resolved]
org.apache.commons.jxpath (1.3.0.v200911051830) "Apache Commons JXPath" [Resolved]
org.apache.felix.gogo.command (0.10.0.v201209301215) "Apache Felix Gogo Command" [Active]
org.apache.felix.gogo.runtime (0.10.0.v201209301036) "Apache Felix Gogo Runtime" [Active]
org.apache.felix.gogo.shell (0.10.0.v201212101605) "Apache Felix Gogo Shell" [Active]
org.apache.jasper.glassfish (2.2.2.v201501141630) "JSP 2.2 implementation from Glassfish" [Resolved]
org.apache.lucene.analysis (3.5.0.v20120725-1805) "Apache Lucene Analysis" [Resolved]
org.apache.lucene.core (3.5.0.v20120725-1805) "Apache Lucene Core" [Resolved]
org.csstudio.swt.widgets (2.1.0.201209121549) "SWT XYGraph Widgets" [Resolved]
org.csstudio.swt.xygraph (2.1.0.201209121540) "XYGraph Plug-in" [Resolved]
org.eclipse.core.commands (3.7.0.v20150422-0725) "Commands" [Resolved]
org.eclipse.core.contenttype (3.5.0.v20150421-2214) "Eclipse Content Mechanism" [Active]
org.eclipse.core.databinding (1.5.0.v20150422-0725) "JFace Data Binding" [Starting]
org.eclipse.core.databinding.beans (1.3.0.v20150422-0725) "JFace Data Binding for JavaBeans" [Resolved]
org.eclipse.core.databinding.observable (1.5.0.v20150422-0725) "JFace Data Binding Observables" [Active]
org.eclipse.core.databinding.property (1.5.0.v20150422-0725) "JFace Data Binding Properties" [Starting]
org.eclipse.core.expressions (3.5.0.v20150421-2214) "Expression Language" [Active]
org.eclipse.core.jobs (3.7.0.v20150330-2103) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.net (1.2.300.v20141118-1725) "Internet Connection Management" [Starting]
org.eclipse.core.runtime (3.11.1.v20150903-1804) "Core Runtime" [Active]
org.eclipse.draw2d (3.10.1.201508170204) "Graphical Editing Framework Draw2d" [Active]
org.eclipse.e4.core.commands (0.11.0.v20150422-0725) "Eclipse e4 core commands" [Active]
org.eclipse.e4.core.contexts (1.4.0.v20150828-0818) "Eclipse Contexts" [Active]
org.eclipse.e4.core.di (1.5.0.v20150421-2214) "Eclipse Dependency Injection" [Active]
org.eclipse.e4.core.di.annotations (1.4.0.v20150528-1451) "Eclipse Dependency Injection Annotations" [Resolved]
org.eclipse.e4.core.di.extensions (0.13.0.v20150421-2214) "Eclipse Dependency Injection Extensions" [Active]
org.eclipse.e4.core.services (2.0.0.v20150403-1912) "Eclipse Application Services" [Active]
org.eclipse.e4.emf.xpath (0.1.100.v20150513-0856) "Eclipse Model Xpath" [Resolved]
org.eclipse.e4.ui.bindings (0.11.0.v20150422-0725) "Eclipse Bindings Support" [Active]
org.eclipse.e4.ui.css.core (0.11.0.v20150511-1937) "Eclipse CSS Core Support" [Resolved]
org.eclipse.e4.ui.css.swt (0.12.0.v20150511-1003) "Eclipse CSS SWT Support" [Active]
org.eclipse.e4.ui.css.swt.theme (0.10.0.v20150422-0725) "Eclipse CSS SWT Theme Support" [Active]
org.eclipse.e4.ui.di (1.1.0.v20150422-0725) "Eclipse UI Dependency Injection" [Active]
org.eclipse.e4.ui.dialogs (1.0.0.v20150513-0856) "Eclipse e4 dialogs" [Resolved]
org.eclipse.e4.ui.model.workbench (1.1.100.v20150407-1430) "Eclipse Workbench Model" [Active]
org.eclipse.e4.ui.services (1.2.0.v20150422-0725) "Eclipse UI Application Services" [Active]
org.eclipse.e4.ui.widgets (1.1.0.v20150427-1751) "Eclipse UI Custom widgets" [Resolved]
org.eclipse.e4.ui.workbench (1.3.1.v20160203-0951) "Eclipse e4 Workbench" [Active]
org.eclipse.e4.ui.workbench.addons.swt (1.2.0.v20150512-1414) "Eclipse e4 Workbench Add-ons" [Active]
org.eclipse.e4.ui.workbench.renderers.swt (0.13.0.v20150901-1347) "Eclipse e4 Workbench SWT Renderer" [Active]
org.eclipse.e4.ui.workbench.swt (0.13.0.v20150504-0621) "Eclipse e4 Workbench SWT" [Active]
org.eclipse.e4.ui.workbench3 (0.13.0.v20150422-0725) "Bundle for Workbench APIs available in e4" [Resolved]
org.eclipse.emf.common (2.11.1.v20160208-0816) "EMF Common" [Active]
org.eclipse.emf.ecore (2.11.2.v20160208-0816) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.11.0.v20160208-0816) "EMF Change Model" [Starting]
org.eclipse.emf.ecore.xmi (2.11.1.v20160208-0816) "EMF XML/XMI Persistence" [Active]
org.eclipse.equinox.app (1.3.300.v20150423-1356) "Equinox Application Container" [Active]
org.eclipse.equinox.bidi (0.10.0.v20130327-1442) "Bidirectional Text Support" [Starting]
org.eclipse.equinox.common (3.7.0.v20150402-1709) "Common Eclipse Runtime" [Active]
org.eclipse.equinox.console (1.1.100.v20141023-1406) "Console plug-in" [Active]
org.eclipse.equinox.ds (1.4.300.v20150423-1356) "Declarative Services" [Active]
org.eclipse.equinox.event (1.3.100.v20140115-1647) "Event Admin" [Active]
org.eclipse.equinox.http.jetty (3.1.2.v20160115-1350) "Jetty Http Service" [Starting]
org.eclipse.equinox.http.registry (1.1.300.v20130402-1529) "Http Service Registry Extensions" [Resolved]
org.eclipse.equinox.http.servlet (1.2.2.v20160202-2102) "Http Services Servlet" [Starting]
org.eclipse.equinox.jsp.jasper (1.0.500.v20150119-1358) "Jasper Jsp Support Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.300.v20130327-1442) "Jasper Jsp Registry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.3.100.v20150511-1540) "Equinox Launcher" [Resolved]
org.eclipse.equinox.launcher.win32.win32.x86 (1.1.300.v20150602-1417) "Equinox Launcher Win32 X86 Fragment" [Resolved]
org.eclipse.equinox.p2.core (2.4.0.v20150527-1706) "Equinox Provisioning Core" [Active]
org.eclipse.equinox.p2.director (2.3.200.v20150423-1455) "Equinox Provisioning Director" [Active]
org.eclipse.equinox.p2.engine (2.4.0.v20150511-1532) "Equinox Provisioning Engine" [Active]
org.eclipse.equinox.p2.metadata (2.3.0.v20150511-1532) "Equinox Provisioning Metadata" [Active]
org.eclipse.equinox.p2.metadata.repository (1.2.200.v20150428-1613) "Equinox Provisioning Metadata Repository" [Active]
org.eclipse.equinox.p2.operations (2.4.100.v20150423-1455) "Equinox Provisioning Operations API" [Active]
org.eclipse.equinox.p2.repository (2.3.100.v20150428-1613) "Equinox Provisioning Repository" [Active]
org.eclipse.equinox.preferences (3.5.300.v20150408-1437) "Eclipse Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.6.0.v20150318-1503) "Extension Registry Support" [Active]
org.eclipse.equinox.security (1.2.100.v20150423-1356) "Equinox Java Authentication and Authorization Service (JAAS)" [Active]
org.eclipse.equinox.simpleconfigurator (1.1.100.v20150423-1455) "Simple Configurator" [Active]
org.eclipse.equinox.util (1.0.500.v20130404-1337) "Equinox Util Bundle" [Active]
org.eclipse.help (3.6.0.v20130326-1254) "Help System Core" [Active]
org.eclipse.help.base (4.0.301.v20160212-1500) "Help System Base" [Starting]
org.eclipse.help.ui (4.0.100.v20140401-0608) "Help System UI" [Starting]
org.eclipse.help.webapp (3.7.0.v20150425-0643) "Help System Webapp" [Starting]
org.eclipse.jetty.http (9.2.13.v20150730) "Jetty :: Http Utility" [Resolved]
org.eclipse.jetty.io (9.2.13.v20150730) "Jetty :: IO Utility" [Resolved]
org.eclipse.jetty.security (9.2.13.v20150730) "Jetty :: Security" [Resolved]
org.eclipse.jetty.server (9.2.13.v20150730) "Jetty :: Server Core" [Resolved]
org.eclipse.jetty.servlet (9.2.13.v20150730) "Jetty :: Servlet Handling" [Resolved]
org.eclipse.jetty.util (9.2.13.v20150730) "Jetty :: Utilities" [Resolved]
org.eclipse.jface (3.11.1.v20160128-1644) "JFace" [Active]
org.eclipse.jface.databinding (1.7.0.v20150406-2148) "JFace Data Binding for SWT and JFace" [Resolved]
org.eclipse.osgi (3.10.102.v20160118-1700) "OSGi System Bundle" [Active]
org.eclipse.osgi.compatibility.state (1.0.100.v20150402-1551) "Equinox State and Resolver Compatibility Fragment" [Resolved]
org.eclipse.osgi.services (3.5.0.v20150519-2006) "OSGi Release 4.2.0 Services" [Resolved]
org.eclipse.swt (3.104.2.v20160212-1350) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.104.2.v20160212-1350) "Standard Widget Toolkit for Windows" [Resolved]
org.eclipse.ui (3.107.0.v20150507-1945) "Eclipse UI" [Active]
org.eclipse.ui.forms (3.6.200.v20150506-2029) "Eclipse Forms" [Active]
org.eclipse.ui.workbench (3.107.1.v20160120-2131) "Eclipse Workbench" [Active]
org.eclipse.update.configurator (3.3.300.v20140518-1928) "Install/Update Configurator" [Active]
org.eclipse.wb.swt.widgets.baseline (1.8.0.r45x201506110827) "SWT Baseline Support" [Active]
org.sat4j.core (2.3.5.v201308161310) "SAT4J Core" [Resolved]
org.sat4j.pb (2.3.5.v201404071733) "SAT4J Pseudo" [Resolved]
org.slf4j.api (1.7.2.v20121108-1250) "SLF4J API" [Resolved]
org.tukaani.xz (1.3.0.v201308270617) "XZ data compression" [Resolved]
org.w3c.css.sac (1.3.1.v200903091627) "W3C CSS SAC" [Resolved]
org.w3c.dom.events (3.0.0.draft20060413_v201105210656) "W3C DOM Level 3 Events" [Resolved]
org.w3c.dom.smil (1.0.1.v200903091627) "W3C SMIL DOM" [Resolved]
org.w3c.dom.svg (1.1.0.v201011041433) "W3C SVG DOM" [Resolved]
*** User Preferences:
#Thu Oct 26 23:54:31 IST 2023
/bundle_defaults/com.ti.evswsdk.sbsview/PercentageCharge=0
/bundle_defaults/com.ti.evswsdk.sbsview/PercentageDischarge=100
/instance/com.ti.evswsdk.proview/writeBlock_dec=68
/bundle_defaults/org.eclipse.ui/ALTERNATE_OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.ui.workbench/EDITORLIST_DISPLAY_FULL_NAME=false
/bundle_defaults/org.eclipse.ui.workbench/OPEN_AFTER_DELAY=false
/bundle_defaults/org.eclipse.ui/VIEW_MINIMUM_CHARACTERS=1
/bundle_defaults/org.eclipse.ui.workbench/COLOR_ICONS=true
/bundle_defaults/com.ti.evswsdk.sbsview/Separator=,
/bundle_defaults/org.eclipse.ui.workbench/SELECT_ON_HOVER=false
/bundle_defaults/com.ti.evswsdk.global/bqSBBEV2400I2CClockSpeed=Low
/bundle_defaults/com.ti.evswsdk.sbsview/PercentageChrgMV=9000
/bundle_defaults/com.ti.evswsdk.sbsview/PercentageDischrgMV=15300
/bundle_defaults/org.eclipse.ui.workbench/HeapStatus.showMax=false
/instance/com.ti.evswsdk.proview/ReadWord_hex=44
/bundle_defaults/com.ti.evswsdk.sbsview/RemainingCapacityAlarm=false
/bundle_defaults/com.ti.evswsdk.global/bqSBBViewType=0
/instance/org.eclipse.help.base/scope=
/bundle_defaults/org.eclipse.ui/EDITOR_TAB_POSITION=128
/bundle_defaults/org.eclipse.ui.workbench/BIDI_SUPPORT=false
/bundle_defaults/org.eclipse.ui/initialFastViewBarLocation=bottom
/bundle_defaults/com.ti.evswsdk.sbsview/TimeFormat=HH\:mm\:ss
/bundle_defaults/org.eclipse.ui/OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.ui/SHOW_OPEN_ON_PERSPECTIVE_BAR=true
/instance/org.eclipse.help.ui/browser.y=64
@com.ti.evswsdk.proview=1.2.1.202005080856
/bundle_defaults/org.eclipse.ui.workbench/EDITORLIST_SORT_CRITERIA=0
/instance/org.eclipse.help.ui/browser.maximized=false
/instance/org.eclipse.help.ui/browser.x=64
/instance/com.ti.evswsdk.proview/Command_dec=6
/bundle_defaults/com.ti.evswsdk.sbsview/Log\ Interval=4000
/instance/org.eclipse.help.ui/browser.w=1425
/bundle_defaults/org.eclipse.ui.workbench/EDITOR_TAB_WIDTH=3
/bundle_defaults/com.ti.evswsdk.sbsview/SBSFlagTableFontHL=1|Arial|8.0|1|WINDOWS|1|0|0|0|0|700|0|0|0|1|0|0|0|0|Arial
/bundle_defaults/org.eclipse.ui/SHOW_SYSTEM_JOBS=false
/bundle_defaults/org.eclipse.ui.workbench/ENABLE_CONFIGURABLE_PROJECT_WIZARD=false
/bundle_defaults/com.ti.evswsdk.sbsview/Take_Action_When_Dis=1
/bundle_defaults/org.eclipse.ui/PROMPT_WHEN_SAVEABLE_STILL_OPEN=true
/bundle_defaults/org.eclipse.ui/KEY_CONFIGURATION_ID=org.eclipse.ui.defaultAcceleratorConfiguration
/bundle_defaults/com.ti.evswsdk.sbsview/FullyCharged=false
/bundle_defaults/org.eclipse.ui.workbench/coolBarVisible=true
file_export_version=3.0
/bundle_defaults/org.eclipse.ui.workbench/SINGLE_CLICK_METHOD=0
/instance/org.eclipse.help.ui/browser.h=768
/bundle_defaults/org.eclipse.ui.workbench/RECENT_FILES=4
/bundle_defaults/org.eclipse.ui.workbench/OPEN_PERSPECTIVE_MODE=0
/bundle_defaults/org.eclipse.ui/ENABLE_32_STICKY_CLOSE_BEHAVIOR=false
/bundle_defaults/org.eclipse.ui.workbench/OPEN_ON_SINGLE_CLICK=false
/bundle_defaults/com.ti.evswsdk.sbsview/DateFormat=yyyy-MM-dd
/instance/org.eclipse.ui/SHOW_TRADITIONAL_STYLE_TABS=false
/bundle_defaults/org.eclipse.ui.workbench/ENABLED_DECORATORS=
/bundle_defaults/com.ti.evswsdk.sbsview/FullyDischarged=false
@org.eclipse.help.base=4.0.301.v20160212-1500
/instance/com.ti.evswsdk.proview/ReadWord_dec=68
/bundle_defaults/org.eclipse.ui.workbench/USE_IPERSISTABLE_EDITORS=true
/bundle_defaults/org.eclipse.ui/LINK_NAVIGATOR_TO_EDITOR=false
/bundle_defaults/org.eclipse.ui.workbench/ENABLE_COOL_BARS=true
/bundle_defaults/com.ti.evswsdk.sbsview/OverTemperatureAlarmSet=false
@com.ti.evswsdk.dataflashview=1.3.0.202005080856
/bundle_defaults/org.eclipse.ui.workbench/MULTI_KEY_ASSIST=true
/bundle_defaults/org.eclipse.ui.workbench/REUSE_DIRTY_EDITORS=true
/bundle_defaults/org.eclipse.ui/CLOSE_EDITORS_ON_EXIT=false
/bundle_defaults/com.ti.evswsdk.sbsview/TerminateChargeAlarmSet=false
/bundle_defaults/org.eclipse.ui.workbench/TEXT_DIRECTION=
/bundle_defaults/org.eclipse.ui/USE_WINDOW_WORKING_SET_BY_DEFAULT=false
/bundle_defaults/org.eclipse.ui.workbench/perspectiveBarVisible=true
/bundle_defaults/org.eclipse.ui.workbench/NL_EXTENSIONS=
/bundle_defaults/org.eclipse.ui/RECENTLY_USED_WORKINGSETS_SIZE=5
/instance/com.ti.evswsdk.proview/readBlock_hex=44
/bundle_defaults/org.eclipse.ui.workbench/MULTI_KEY_ASSIST_TIME=1000
/bundle_defaults/com.ti.evswsdk.global/BitFlagHigh=205,92,92
/bundle_defaults/com.ti.evswsdk.sbsview/RemainingTimeAlarm=false
/bundle_defaults/org.eclipse.ui.workbench/REUSE_OPEN_EDITORS_BOOLEAN=false
/bundle_defaults/org.eclipse.ui/EDITOR_MINIMUM_CHARACTERS=-1
/instance/com.ti.evswsdk.dataflashview/lastggImportPath=C\:\\Users\\jvsingh\\OneDrive - Intel Corporation\\Documents\\Workarea\\PCCG\\ADL\\ProCompete assessment\\PCM\\BMSpower\\PVT
/bundle_defaults/org.eclipse.ui.workbench/shouldPromptForEnablement=true
/bundle_defaults/com.ti.evswsdk.sbsview/OverchargedAlarmSet=false
/bundle_defaults/org.eclipse.ui.workbench/KEYS_PREFERENCE_SELECTED_TAB=0
/bundle_defaults/org.eclipse.ui/disableNewFastView=false
/instance/com.ti.evswsdk.proview/writeWord_hex=81
/bundle_defaults/org.eclipse.ui/ENABLE_DETACHED_VIEWS=true
/bundle_defaults/org.eclipse.ui.workbench/STICKY_CYCLE=false
/bundle_defaults/org.eclipse.ui/PROJECT_OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.ui/VIEW_TAB_POSITION=128
/bundle_defaults/org.eclipse.ui.workbench/REUSE_OPEN_EDITORS=8
/bundle_defaults/org.eclipse.ui/DOCK_PERSPECTIVE_BAR=topLeft
/bundle_defaults/com.ti.evswsdk.sbsview/ChargeRisesAbove=true
/bundle_defaults/com.ti.evswsdk.sbsview/ChargeDropsBelow=true
/bundle_defaults/com.ti.evswsdk.sbsview/ElapsedTimeIntervalFormat=s.SSS
/bundle_defaults/org.eclipse.ui/USE_COLORED_LABELS=true
/instance/com.ti.evswsdk.proview/text_block_writeblockdata_string=00 06
/instance/com.ti.evswsdk.proview/text_block_ascii_string=T
/bundle_defaults/com.ti.evswsdk.sbsview/VoltRisesAbove=false
/bundle_defaults/com.ti.evswsdk.sbsview/ChgrCtrlPin=2
/bundle_defaults/com.ti.evswsdk.sbsview/VoltDropsBelow=false
/instance/com.ti.evswsdk.proview/readBlock_dec=68
/bundle_defaults/org.eclipse.ui/SHOW_OTHER_IN_PERSPECTIVE_MENU=true
/instance/com.ti.evswsdk.proview/text_block_readblockdata_string=54 00 87 02 00 00
/bundle_defaults/org.eclipse.ui/ENABLE_MIN_MAX=true
/bundle_defaults/org.eclipse.ui/SHOW_MULTIPLE_EDITOR_TABS=true
/bundle_defaults/com.ti.evswsdk.global/BitFlagIntermediate=255,255,255
/bundle_defaults/org.eclipse.ui.workbench/overridepresentation=false
/instance/com.ti.evswsdk.proview/writeBlock_hex=44
/bundle_defaults/org.eclipse.ui.workbench/DISABLE_DIALOG_FONT=false
/bundle_defaults/com.ti.evswsdk.sbsview/TerminateDischargeAlarm=false
/bundle_defaults/org.eclipse.ui/showIntro=true
/bundle_defaults/com.ti.evswsdk.sbsview/Take_Action_When_Ch=1
/bundle_defaults/org.eclipse.ui.workbench/EDITORLIST_SELECTION_SCOPE=1
/bundle_defaults/org.eclipse.ui/SHOW_TRADITIONAL_STYLE_TABS=true
/bundle_defaults/org.eclipse.ui.workbench/LAYOUT_DIRECTION=0
/instance/com.ti.evswsdk.proview/writeWord_dec=129
/bundle_defaults/org.eclipse.ui/SHOW_TEXT_ON_PERSPECTIVE_BAR=true
/bundle_defaults/com.ti.evswsdk.sbsview/Scan\ Interval=4000
/bundle_defaults/org.eclipse.ui/SHOW_FILTERED_TEXTS=true
/bundle_defaults/org.eclipse.ui.workbench/SHOW_MEMORY_MONITOR=false
/bundle_defaults/org.eclipse.ui.workbench/HeapStatus.updateInterval=500
@org.eclipse.help.ui=4.0.100.v20140401-0608
/bundle_defaults/com.ti.evswsdk.global/BitFlagLow=50,205,50
/bundle_defaults/org.eclipse.ui.workbench/WORKBENCH_SAVE_INTERVAL=5
/bundle_defaults/org.eclipse.ui/SHIFT_OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/instance/com.ti.evswsdk.proview/Command_hex=06
@org.eclipse.ui=3.107.0.v20150507-1945
/bundle_defaults/org.eclipse.ui/ENABLE_ANIMATIONS=false
/bundle_defaults/com.ti.evswsdk.sbsview/SBSTableFont=1|Arial|8.0|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Arial
/bundle_defaults/org.eclipse.ui.workbench/DISABLE_OPEN_EDITOR_IN_PLACE=false
/bundle_defaults/org.eclipse.ui.workbench/EDITORLIST_PULLDOWN_ACTIVE=false
/bundle_defaults/org.eclipse.ui.workbench/ENABLE_NEW_MENUS=true
errorLog.txt
  • *** Date: Thursday 26 October 2023 at 11:54:31 pm India Standard Time
    win32
    -ws
    win32
    -arch
    x86
    -showsplash
    -launcher
    -name
    Bqsbb
    --launcher.library
    -startup
    -persistState
    false
    -vm
    -Xms40m
    -Xmx512m
    equinox.use.ds=true
    file.separator=\
    line.separator=
    os.arch=x86
    os.name=Windows 10
    os.version=10.0
    osgi.arch=x86
    osgi.nl=en_IN
    osgi.os=win32
    osgi.ws=win32
    path.separator=;
    sun.desktop=windows
    sun.os.patch.level=
    user.country=IN
    user.language=en
    user.name=jvsingh
    user.script=
    user.variant=
    *** Features:
    Config file also added here.
    Any pointers much appreciated.
    thanks,
    Jagadish
  • Hi Jagadish,
    When writing to the MAC commands, the bits need to be flipped in the initial write. Below is an example of this for reading the ChemID:
    Completing a block read for a register like 0x0077 can be done in the same fashion as well, seen below:
    Please let me know if this helps.
    Anthony Baldino
  • Hi Anthony,
    thanks... But this does not help.
    I tried even this combination, but it gave me the same response.
    54 00 87 02 00 00
    I did not capture the screenshot though.
    Does this bit pattern indicate anything?
  • I'm wondering if it is anything to do with the dashboard scan. Will check this first thing on Monday morning and update.
  • Turning off dashboard scan helped. Able to read the register for chemID now.
    Can anyone confirm on the below response for the seal and unseal commands? Is it expected to say N/A a shown below?
  • Hi Jagadish,
    Yes, that is the appropriate response for UNSEAL. The quickest way to see what mode the gauge is in is by the icon depicted next to the device on bqStudio.
    Sealed:
    Unsealed:
    Unsealed Full Access:
    Anthony Baldino
  • Thanks Anthony. This helps. Also, the dashboard scanner was the problem. With that disabled, I could get block read working. The misleading part is that some of the commands work even with scanner on.. like when reading RSoC.
