Other Parts Discussed in Thread: TPS7A92, TPS7A57, TPS74401
Hi Team,
i have used TPS7A52 in our design to generate 0.8v which it supports. There was no R1 and R2 values defined for 0.8v in the datasheet.
in order to get 0.808 volts, I calculated the resistor values to be 100ohm as R1 and 100k as R2. With this configuration, i dont see any voltage at the outpit.
Could you share me proper resistor to use for R1 and R2 in getting a voltage very close to 0.8V
Kishore.
