TPS65987D: solution for AMD R2312
Part Number: TPS65987D
Hi
Customer application is USB PD + DP Alt Mode.
The Host CPU is AMD R2312. Now RnD surveys TI solution TPS65987D(USB PD)+TUSB1046(MUX to Display Port Alt Mode).
Is it suitable? Is there FW code supported AMD R2312?
If not, Could you kindly suggestion suitable solution for AMD R2312?
Thanks & best regards,
  • Hi David,
    The solution you've listed should be suitable for the AMD R2312. Please know this is a very old processor at AMD, so there may not be a lot reference material or familiarity with this processor to support this type of design.
    Matt Schafer
