BQ40Z80: Parallel Charge and Discharge Paths
Part Number: BQ40Z80
Does BQ40Z80 support parallel charge and discharge paths?
  • Hello Jayesh,
    Yes it can support parallel power path, but when going between shutdown and wakeup there must be care taken in order for voltage on PACK to be applied since it is not on the charge path which is the normal method for wakeup. You will need some type of button or other method to apply the wakeup voltage.
    Sincerely,
    Wyatt Keller
