TPS25940-Q1: Component failing/fusing, there is no Output
Part Number: TPS25940-Q1
As we used this component in one of our designs. I want to know, at what conditions this E-fuse will fail. As the Input voltage is  13.6V nominal and current 2A peak. Please check the Image attached for your reference. After few hours of usage this component is failing(no output), we replaced the component, the device started working. It happened to 4 devices for now. As we are going to production next month, this situation is so horrific. Please help resolve this issue ASAP.
regards
ANISH.M
