TPS546D24: PM bus IC
Part Number: TPS546D24
TPS546D24
I need to know weather the above mentioned ic can work without PM BUS communication ? Will it work only with the harware connections?
we need a reference circuit of TPS546D24 for hardware configuration without any I2C interface communication.
  • Hi Abhinay,
    This device can work without the PMBus connection.
    You can configure the device through the 4 pin strapping pins: MSEL1, MSEL2, VSEL, and ADRSEL.
    There is a schematic of our EVM in the EVM user guide that you can request from the product page: TPS546D24EVM-856 Evaluation board | TI.com
    For calculating all the pin-strapping resistors, I recommend using our calculator spreadsheet, which can be found after requesting more info on the datasheet.
    Joseph
