LMG2610: Can not open the TI’s GaN power loss calculator tools
Part Number: LMG2610
I al interested in estimating the power loss in the LMG2610 GaN Half-Bridge for ACF Converters.
Nevertheless, I can not use the downloaded file from TI's site. It is a .p Matlab file, and even if I followed the "How to use" note from TI, nothing works. The command window brings back : "class name and filename must match".
Thank you for your help,
-CL
  • Hi Constance,
    Thanks for your interest in LMG2610. I believe you are referring to LMGXX-GAN-LLC-CALC, which is a loss calculator for LLC converters. We are aware of this issue with the MATLAB file and are working to reupload the correct file.
    However, if you are interested in the power loss calculator for ACF converters, please download the LMG2610 Active-Clamp Flyback Power Stage Design Calculator. This calculator is excel based and there should be no issue running it.
    Let me know if this helps.
    John
