Part Number: LP5036
HI engineers:
I have some problems about LP5036:
While using the LP5036, I noticed that when the input data changes from 0X7F to 0X80, the output PWM duty cycle undergoes a sudden change. I'm concerned that this might be a bug, so I'm hoping you can check and confirm if this issue exists, and provide a solution. My configuration information is: 9Bits, linear adjustment mode. Thank you very much for your help, and I look forward to your response.
