We are using LM22672 in a buck / inverter circuit stepping down from +24 V to ±16.8 V. We are seeing an issue on multiple boards where the switch node isn't going all the way to ground:
On a good board it does:
When this happens, the negative rail ends up shifted due to the DC offset on the switch node. What would cause this behavior?
