BQ76952: Issue importing *.gg.csv file using BQStudio Version : 1.3.123 Build 1
Part Number: BQ76952
Other Parts Discussed in Thread: BQSTUDIO,
as described in the title we have issues importing *.gg.csv files using BQStudio Version : 1.3.123 Build 1.
We needo to use this version because the stable releases does´nt seem to work properly with the BQ76952 device.
Anyway, the import works on all parameters but "Custom Temperature Model". Do you also have any experiences like this and any advice how to handle this issue?
If I write the register values manually one by one everthing works fine. But the automatic import is not able to write the values into the device registers.
Thank you in advance for your help.
Best Regards
Mathias
