Hello Dear,
We have an application where we developed a power supply using LM5021. Its input voltage range is 90 VDC to 280 VDC and output is 13VDC.
Power supply is designed for 20W. In our application we do not need the skip cycle feature so, we have bypassed this feature by adding 175mV offset using VCC pin supply. But, still it is observed that there is a skip cycle at higher voltages. (220-280VDC).
Can you pls suggest how to overcome tjis issue or completly bypass skip cycle.
