I am using LM74502 for load dump protection. In the evaluation board, there is an RC block for the FET.
So should I place these components for my project?
Best regards.
Best regards.
Hi Aksoy
Thanks for reaching out to us!
This RC block is present to limit the inrush current if you have high value capacitors at the output. If this functionality is not needed, the RC block can be removed.
Thanks and Regards
Shiven Dhir
Thanks for the reply
At the output side, there is a 100u Electrolytic polymer Capacitor with low ESR (28mOhm). Is that suitable for limiting the inrush current?
Best regards.
Hi Aksoy
It depends on how fast your input voltage rises. Although the ESR will help in limiting the current but can be limited further to whatever value you want using the RC block.
Thanks and Regards
Shiven Dhir
