Other Parts Discussed in Thread: PSPICE-FOR-TI
Hi, Dear product line
my customer configure LMZM23601 as a inverting regulator as below figure shows.
then customer find he could not disable LMZM23601 with a FPGA_IO directly. Ithink the EN pin should refer GND of chip. So I propose custome use a photo-mos or optical-couple to disable/enable LMZM23601. but the photo-mos or optical couple is too big for customer since the PCB area is quite tight. I also propose a zener/transistor for disable/enable. but I could not simulate it since Pspice-For-TI has no zener. Do you have any good idea? thanks.
regards,
Bill
