Hello Team,
Good Day!
We are facing an issue with ULN2003A.
We are using ULN2003ADR to drive relays in our design.Atmega2560AU is used as the main controller. In that when we are connecting the ULN's 9th Pin (COM) to 12V the relays are working fine but when we lifting the 9th pin some relays are working and other relays are not working but the voltage is proper between the relay coil.What may be the reason for that? Do we need to consider anything in the layout or schematics? Kindly find the attached schematics for reference.
