LP55231: Limits of the external (32kHz) clock frequency range.
Part Number: LP55231
Is it the case, that by toggling the external 32kHz 'CLK' pin on the LP55231 RGB LED driver at a higher rate that 32kHz, the PWM frequency will be increased proportionally?
Assuming that this is the case, and if we accept this will also affect timings in sequences in a similar way, please can you provide an upper limit to the clock frequency.
