Part Number: TPS62933P
Other Parts Discussed in Thread: TPS54302
I'm seeing unusual behavior while current probe is inserted at the output of DC-DC converter. Once I remove the probe, output waveform become normal. It is also not oscillating with constant current load. I checked loop gain without current probe and it looked fine with 55deg of phase margin. I attached several waveforms below for reference.
Model of current probe is Tektronix TCP202.
Do you have any idea why the converter is oscillating?
Figure1. Output oscillation
Figure 2. Loop gain
