TPS51610: PMIC for Intel Atom E660T
Part Number: TPS51610
today customer use DA6011-02HDA1 to supply Intel Atom E660T and needs an alternative solution. Is the TPS51610 our recommendation which I saw in the PMP5835?
Regards, Holger
  • Hi Holger,
    For that particular design and platform (Tunnel Creek), I do believe that TPS51610 is our recommendation and is compatible. However, since we do not have the spec for DA6011-02HDA1, we cannot tell if TPS51610 fully replaces the solution since the customer might have other requirements that are accounted for when choosing a solution.
    If you could provide more specs, we can let you know if there are other products that we'd better recommend.
    Thank you,
    Dhanya Prem
