TPS548C26: Questions of TPS548C26
Part Number: TPS548C26
Other Parts Discussed in Thread: TPS548D22, TPS53355
Hi Team,
Customer got feedback from their sourcing team that there is another solution, TPS548C26, which is 35A solution and the similar function as TPS548D22 and possibly may have replacement on TPS53355 as well.
I also simulated it on WEBENCH and simulation result as attached. The performance of TPS548D22 and TPS548C26 are evenly matched. For Vout tolerance, TPS548D22 is a bit better. For the efficiency, TPS548C26 is a bit better.
Compare to TPS548D22, will you recommend to use TPS548C26 for 0.875V core voltage? Or keep using TPS548D22 as is will be more suitable?
TPS548C26_0V875_16A0.pdfTPS548D22_0V875_16A0.pdf
Many Thanks,
Jimmy
