TPS548C26: Questions of DRV2603
Part Number: TPS548C26
Dear Team,
I have a question need to check with you.
According to Webench suggest schematic, what is the Cnoise is used for?
I saw the Cnoise can be de-pop on other project of our team.
So I’m checking with you about Cnoise is necessary or not?
If it is de-pop, will the action cause another side effect?
Many Thanks,
Jimmy
  • Hi Jimmy,
    A response for this will be posted next week. Please expect a delay due to the holidays.
    Calan
  • Hi Jimmy,
    The Cnoise can also be called the feedforward cap, or C_FF.
    Typically, it is used to improve transient performance or enhance stability of higher VOUT rails.
    If you fill in the device calculator: TPS548C26-CALC Calculation tool | TI.com. On line 111 it will tell you if a CFF is recommended or not, then it will help you calculate the desired CFF.
    If the C_FF is not needed, it is sometimes handy to have it de-pop on the PCB in case you want to "tweak" the compensation to improve transient performance/stability after the PCB is created.
    Joseph
